Yamaha 01 250 OX66 running rough. Trying to figure it out.
Cslider
My 2001 Yamaha OX66 250hp was running real rough when idling. Would turn off too. I checked compression and I am at 115 on all 6 cylinders. I changed the VST filter, had the fuel injectors cleaned as well by injector-man. New primer bulb and rancor filter. Also 3 new fuel pumps. As well as the filter replaced in the motor. What else could be still causing it to run rough? Please help me out on what I may have missed
  • IMG_0696.MOV
Cslider
I did clean the O2 Sensor and the barbell. Had some carbon build up on it. Still ran rough so I changed the 02 Sensor to another one I had. Still same thing. Was raining all day today so wasn’t able to work on it more. But going to check all the coils and spark tomorrow hopefully.
flyingscott
Gonna need to scan it. Who cleaned your injectors? Was there a flow and pattern test done to them?
crazy charlie
Ignition wires?? Run it in the dark and look for arcing or just change out the wires.Charlie
Cslider
Yes. I had them done professionally and got the flow chart back. All even now and cleaned with new filters
