Yam FT9.9EXH barely starts, stalls with throttle increase
murphyjh
I can get this 1988 motor to idle only by reducing the idle speed setting, and even then, it idles roughly. It will turn the prop at idle in a tank. However any attempt to speed it up causes it to stall immediately. Even in neutral, any slight opening of the throttle butterfly makes it stall. Compression is good (130-135), but the plugs are wet with gasoline.<br /><br />I have taken the carb apart, and found the main jet completely clogged. Fixed it. Everything else looked good. The float is at the right level, and I ran wires through all orifices.<br /><br />It appears to be running rich, which could cause the idle to be rough. When I open the throttle, I don't know whether it stays too rich or suddenly becomes lean.<br /><br />This leads me to the mysterious Bimetallic Vacuum Switching (BVS) valve system on this motor, which is a starting enrichment system that senses block temperature and sends vacuum signals to the carb. The Seloc manual has a general description, but no real details (I suspect that they don't understand it either).<br /><br />Has anyone experienced this problem? Is the BVS valve in the block bad? Anything else I can look for in the carb?<br /><br />Jack Murphy :(
murphyjh
Re: Yam FT9.9EXH barely starts, stalls with throttle increase
Followup: I found the problem. The pilot jet became clogged again. This jet feeds the two small ports thst become exposed as the throttle plate opens, accounting for my symptoms.
ST
Hi murphyjh;<br />Was it complicated to take apart the carb? Do you need to replace anything? I might be doing my 86 9.9 carb cleaning before too long myself. :)
murphyjh
ST:<br />It wasn't difficult using the Seloc manual. I didn't replace anything.<br />I found that removing the items on the top of the carb involved many steps that were unnecessary because my problems were in the bottom of the fuel bowl. When I finished, I wrote myself a 5-step mini procedure for my use if the problems return. Here it is, condensed (Seloc item numbers):<br />1. Undo throttle link and remove small hoses marked A and C (marked on hoses and carb).<br />2. Remove the two manifold mounting nuts and washers. Then move the carb so you can remove the fuel line.<br />16A. With the carb out,loosen the large brass drain valve and drain the fuel.<br />12. Drop the bowl (4 screws).<br />13. Watch for the starter nozzle that will fall out of a well in the bowl.<br />17. Pry up the white plastic cap. Use a suitable screwdriver to unscrew the pilot jet in that hole. Also unscrew the main jet next door.<br />That's it. Use fine wires to clean the jet bores. Scrape off any crud; blow through them with air or solvent; and reassemble.
SamalotCj
Originally posted by murphyjh:<br /> Followup: I found the problem. The pilot jet became clogged again. This jet feeds the two small ports thst become exposed as the throttle plate opens, accounting for my symptoms.
I can't tell you how many carburetors I've cleaned due to dirty fuel only to have them return with the same problem. I recommend to every victim of a dirty carb to ditch their remaining fuel and refill. Also make sure to purge the fuel line of any remaining gas as well. In a small outboard it's VERY easy to clog those tiny fuel jets.
ST
Murphyjh;<br />Thanks for your step-by-step procedures; I saved that for my future reference!<br /><br />If these small outboards are so susceptible to dirty fuel; you think it's a good idea to install an in-line fuel filter on them?
ST
Murphyjh;<br />I followed your step-by-step yesterday. Did everything as your post, but I was not able to do step 17: couldn't pry up the white plastic cap! :confused: <br /><br />In fact, I might have ruined it now: using a pair of cutter, instead of pulling it out, I cut the cap! Tried to look for part replacement at BOAT.NET or Yamaha website; but unable to determine which part I need; hard to read those parts drawing! <br /><br />How did you remove that plastic cap? You think I should just leave the cap alone?<br /><br />1986 Yamaha FT9.9ELJ
murphyjh
Sam:<br />Mine came out easily. Here are the part numbers for the plug and its o-ring:<br />6G8-14345-00-00 PLUG,MAIN NOZZLE $1.77<br />654-14198-00-00 GASKET $1.92<br />You can probably drill the piece (less than 1/4" long) out. Use a small bit and drill at an angle to avoid drilling through the hole in the jet. It makes me wonder why Yamaha didn't tap the hole and screw a plug into it.
ST
Murphyjh;<br />Just wanted to follow up: even though my engine model year was 1986; but my carb looks like 1987 model year! The parts you listed is for 1987 and later model year I believe; so I got them ordered (along with other part I needed) from boat.net and already put them back together. Thanks again!
