yahama 70
maryhislop
I am replacing the spark plugs on my outboard motor. I dont have a manual for my yahama 70. Can you tell me what the gap should be?
MCook
Re: yahama 70
Your gap should be .039 inch. If you are using the correct plug the factory gap is good, but it doesn't hurt to check it. Also you should really go invest in a service manual, about $20.<br /><br />Good luck
Jammu
Re: yahama 70
NGK BR8HS-10<br />The last number (10) means the gap (1,0mm)
