Fishermark
- Oct 19, 2003
- 5,617
In the ongoing saga of trying to find and eliminate a leak from the transom area that has been hard to correct, I am pulling the entire transom assembly off and resealing everything.<br /><br />When I put a new engine in my boat last fall, (a 5.7 liter Mercruiser - to replace a 5 liter engine) I noticed that the transom assembly was apparently the wrong one for the boat/engine combination, although it appeared original. Where the "y" pipe bolts up to the transom assembly, the bolt holes did not match up completely. Three did, but one was cocked to the side. Later I saw where that is for a single pipe like found on a four cylinder engine.<br /><br />I went ahead and bolted it up, but, (and this may be a dumb question
), is that likely to cause a problem? Has anyone else done this and had experience good or bad?
