I am working on a 1993 150 xr6. Pulled gearcase to change water pump. Trying to replace the gearcase. I noticed that there is a seal blocking the splines in the crankshaft from engaging with the splines on the driveshaft. Is it possible that the crankshaft/case seal came loose and is floating around there? it is moving freely. How can I fix this problem? Or is it a "less" important seal? Can it be run without this seal?
