Bought this ski in 04 and am just now getting to it (busy these days). Not sure what it needs so I am poorboying it together before spending too much $ on it. It had low compression (85 range) so I pulled it apart. Kind of stumped why it was so low on two of the cylinders because they were so clean (third one scored). My plan is to replace the one scored piston and put a set of new rings in it and see if I can get it running long enough to test all the other componants. The cylinders measure 80mm which appears to be the standard bore. EDIT
Thanks, Kevin
Thanks, Kevin
