Re: Wow, all these years and I've always used regular gas . . .
I thought I'd chime in since the discussion turned towards the ethanol debate. DON'T USE IT! I live in Ohio, and you'll be hard pressed to find a street station that sells ethanol free fuel. I have a test kit that will measure the amount of that crap in the fuel we get. In Ohio, there really is no regulation as how much goes into pump gas. So with that in mind, I've measured anywhere from 4% up to and including 35%, right out of the pump at various places! Now I don't know if most people know this or not, but a lot of manufacturers WILL NOT warrant problems if they discover more than 10% ethanol in your tank if the vehicle or piece of equipment wasn't designed to run it. I have a Harley that STRICTLY prohibits more than 10%. Imagine my surprise when I pulled a test of 13% in my tank! The local marinas are about the ONLY places you can find ethanol free fuel. It's 90 octane, and called "recreation fuel." They HAVE TO run rec fuel, or else their tanks get contaminated with water!
The reason we don't see many issues with ethanol laced fuels in cars is because, generally speaking, autos run a sealed fuel system, whereas outboards, sterndrives, lawn and garden, motorcycles, and most small engines run vented systems. I have a boat that a customer of mine brought to me to work on, and the thing has a hard start problem. I pulled the bowl drains and out comes powder blue colored fuel.....Water contamination was apparent. So I pumped some out of his tank into a clear glass flask. Almost immediately, the fuel started to separate. It had about 30% water in the tank! I know he's running street gas, and he refuses to by the "marina gas" because it's more expensive. Long story short, he's going to end up paying me more to fix this issue that he would if he'd just pony up for the better gas.
And higher octane DOESN'T necessarily mean there's less ethanol. On the contrary, they use ethanol as an octane enhancer. With that in mind, most of the tests I've pulled that register higher were actually higher octane fuel. Now here's the really great part. Ethanol sucks as a fuel. Someone has already stated that it's energy potential is around 25 to25% less than regular petroleum based fuel. That much is certain. It also costs more to refine the stuff to make useable ethanol than it would be to just refine oil, and we'd be further ahead. So you'd figure you'd pay more for the ethanol enhanced stuff correct? Not in Ohio! Here, "rec fuel" is around $5 a gallon from the marina. I know they're paying around $4.11 a gallon for it. Now pull up to a gas station and fill your tank. You're still paying almost $4 a gallon. They get you coming or going. No matter what, they are making you pay for ethanol whether you like it or not. You're getting charged MORE for stuff that actually COSTS LESS to produce, and is better for your equipment!
Ethanol is also a very aggressive solvent. It eats rubber, viton, fiberglass, damn near anything it touches will have been affected with constant use of ethanol. I've seen it eat through an old fiberglass fuel tank, swell viton rubber float needles, shrink cork gaskets, and destroy regular rubber gaskets. It's NO GOOD! If you insist on running it, or have no other option but to run it, be prepared to pony up for fuel system repairs at some time. It's inevitable. I tell my customers to pay me now, or pay me later, because eventually they're going to pay me regardless. Most don't want to hear it, or don't like to hear it. Some will say "I've never had any issues", then come back in a couple months with a fuel system issue.
What can you do if you HAVE no option but to run it? Water separating fuel filters for starters. Keeping your vents to the fuel tanks plugged when stored outside, StarTron seems to help, but once you get water in it, and it separates, there is NOTHING you can do but empty it back out and get fresh. I've had street gas turn in about 2 weeks time. This is NO BS!
OK Rant over for now.....
Ripper
