would this let water into my engine? help needed please
bigdave438
i have a 1982 carver 2667 santacruz,,,260 mercruiser 5.7,,i just started getting water inside my engine, (milky oil) to make a long story short the engine runs great> after i shut the engine off i get water in my #5 cylinder and #3 but not as much...i checked my compression on #5 and its 130lbs...and the other cylinders average 120-130lbs...i removed my intake manifold and replaced the gaskets...i checked my exhaust manifold and riser and this is what i found in my starbard riser IMG-20111008-00215.jpgIMG-20111008-00216.jpg i found this hole and 2 others like it but not as big. my engine idles and runs great no knocking...when i shut the engine off is when i hear loud water gurgling...then i get water in my cylinder again...would this be where water is getting in? (sorry about how the pics posted i didnt know how to fix it)
achris
More fish than mountain goat
Re: would this let water into my engine? help needed please
.....would this be where water is getting in?...
Errrr, ya think???? I would say you have probably found the source of the problem....
Just what I like... A post that answers itself... :D
Chris...........
bigdave438
Chris...........[/QUOTE] thanks...i been racking my brain so much..i couldnt understand how my engine start and idle great with steady idle and then to find water in my cylinder...so would it be safe to say that my engine exhaust push the water out with the exhaust pressure keeping the water out while it was running,,which is why it ran fine..then when the engine is shut off (now no exhaust pressure) the water enters through the hole in the riser and into the exhaust valve?
achris
Excellent, another post that answers its own question... Exactly right...
Man, you are making me look so good... Thanks... :D
bigdave438
im just trying to understand what was going on...everyone at my marina was say cracked block,,cracked head cranked this cracked that...i appreaciated there input but no one could answer my question as to why would my engine run smooth and strong throttle response and good compression....i was just worried very worried about all the crack talk...when i say worried i mean worried...money is tight lol
bigdave438
ok ok i get the hint lol thank you....im just a worry type of guy that likes to fully understand whats happening
achris
ok ok i get the hint lol thank you....im just a worry type of guy who likes to fully understand whats happening
And doing a damn good job of it.... :D
bigdave438
UPDATE>>i didnt feel i totally satisfied that i got to the source of my water intrusion. so i took the intake manifold off and both heads and had a nice surprise waiting for me.....both of my head gaskets were blown and water was leaking into cylinders #4 #6 and #3 and #5...i will post pics of the head gaskets tomorrow...i still dont understand how my engine can idle as if nothing was wrong...those cylinders mentioned were full of water...no rust in any of the cylinders or the block, thank god...i got my shop vac out and vacuumed all cylinders out and totally drained my oil pan...i gave every part a nice oil bath with a clean oil soaked rag.. as well as all cylinders and fill the crankcase with oil,,so hopefully i can keep the rust away...i will be taking the heads to the machine shop tomorrow if their open...
achris
.....both of my head gaskets were blown and water was leaking into cylinders #4 #6 and #3 and #5......
Ouch! :eek:
Idle was probably smooth because cylinder pressures aren't high at idle. You may have run into performance problems under load, mostly just a lack of revs.... Unfortunately V8s tend to behave nicely even up to the point of self-destruction....
Chris........
Wills.WindowsAndWheels
wow interesting thread, very curious to see the pics and the end result. IM a real visual person so i like seeing pictures with dialog to go along with how the WHOLE job went, like you..i like to really understand the full situation as to what happened, why and how it gets fixed :)
bigdave438
sorry i took so long to reply,,had to work some overtime for some extra cash....well i took my heads and intake manifold to the machine shop along with the head gaskets so i can get their input on these gaskets...turns out that the head gaskets were for automobiles not marine and partly to blame for some of the water...the machine shop check the heads and the right side heads had a 2" crack in it running beween the two valves of cylinder #3 ..sorry i left the head gaskets at the shop so i didnt get pics...the outcome..i traded the 2 heads for 2 ready to go rebuilt heads new valves and springs...the intake manifold was in perfect condition....the machine shop ordered and gave me half off of a complete set of fel-pro marine gaskets...and also ordered me a set of head bolts charging me 30 bucks for 2 boxes of head bolts...now im off to my marine to clean the engine block and paint it....any advice from the veterans here and to properly cleaning the clock of all saltwater? and i also had my 4bbl rochester rebuilt....
bigdave438
i can take pics of the engine block and the new heads befor painting and after,,,if u like...
Hell yeah please do lol. If you're feeling extra ambitious and want to document a sort of step by step as to how you reinstall the heads and your process of painting the block id love to see/read it.
bigdave438
quick question???????? i am missing the carburetor choke housing and spring that was attach to my maifold and connects to my 4bbl rochester...i didnt check for it when i got it back from the machine shop (bummer) it was attched when i dropped it off...my engine is a 1982 260 mercruiser...the machine shop is closed, and i tried autozone with no luck...where cn i order one from or is her an electric choke conversion i can order that will work on my carb? i needhelp bad...
