would this fit? 50's -> 80's Evinrude prop
beverly
I own a 1985 Evinrude 8hp
with this prop
and as a temp replacement while i get this one repaired
Would this one fit?
Its from the 1950's (56,57) Evinrude or Jonson
Same shaft dimension all except 2 blade (8" x 8.5P) vs 3 blades (8.5" x 9P). The back is what I can't see or find out what it looks like..
Daviet
Re: would this fit? 50's -> 80's Evinrude prop
If the shaft size, drive pin size are the same and the prop nut fits, and the blades don't hit, use it.
beverly
Update Time...
Now for the rear..
Mine.. 3 Blades
The other.. 2 Blades
One thing I see is the chip on the unbalanced 3 blade prop is causing damage to it's self and the Gearcase Head Assembly.
As for the 2 Blade Prop. No thrust washer and a oversize cap going on the end as its more narrower.
