Would someone please tell me what year this Johnson Outboard motor is?
sandman
I have found a 60HP Johnson Tracker Pro motor with tilt and trim. Model number TJ60TLCEA and serial number G02265953. I need to find a source for what the compression should run on this, and the value of this three cylinder. Any help would be appreciated.<br />Thank you.
kev_79
Re: Would someone please tell me what year this Johnson Outboard motor is?
My references come to a TU60TLCEA being a 1989. FYI: CE is the actual part that indicates the year. I think www2.nadaguides.com can tell you what it might be worth.
Rex
WHAT YEAR?<br />NEED MORE INFORMATION.
sandman
It should be an 1989 year model. I don't know why the numbers do not match???
fone_man
Model number TJ60TLCEA and serial number G02265953<br />---------------------------------------------<br />T = Tracker Model<br /><br />J= Johnson<br /><br />60 = HP<br /><br />T = Trim & Tilt - Electric Start<br /><br />L = 20 inch shaft length<br /><br />CE = 1989 Model Year<br /><br />A = Model Run/Suffix<br /><br />I hope this answers your questions.......<br /><br /> :cool:
