Crosstrained
- May 20, 2012
- 4
I have a 1998 175 FICHT and have been having a problem with the fuel bulb not staying firm, and boat shutting off. If you pump the bulb while under way, the boat will stay running. Have been told that the Lift pump needs replaced. However, when this happens the "No Oil" Light also comes on. Would a drop in fuel pressure to the motor also cause this light to activate? All help greatly appreciated.
