trackertundra
- Jun 11, 2013
- 2
Hi everyone,
I am new to this forum and looking for some advice.
When I replaced the water pump impeller on my 2006 Optimax 150 DFI the other day, I somehow tore the water pump gasket (the top one just underneath the impeller) when I tried to insert the impeller into its housing. Because I did not have another new gasket handy I just used a small amount of grease to seal the tear and then put everything back to the position. I then started the motor in my driveway and it discharged a good stream of water. My question is whether this torn gasket would cause any problem when I run the motor in a high speed on the lake? Do I have to get a new gasket and redo the whole thing again right now or I can wait till I change the impeller next time, may be in a year or two? I understand a small leak from the water pump may result in lower cooling water pressure, but other than that whether the leaking water would damage other part of the motor ?
thanks.
thanks.
