I'm looking into purchasing a new ss prop. I currently have a 19 pitch ss prop. Right now my wot rpm's vary between 5200-5500. Even under the same conditions, me being the solo passenger, the rpm's will vary as stated. SHould I stick with a 19" prop move to a 17" to bring the rpm's up a bit.<br /><br />I believe the recommended wot range is 5500. The 'redline' on the tach reads 5500 as well. Would it be advised not to exceed that range when under full throttle and tring to trim the engine.<br /><br />Thanks
