Had my 1992 Johnson 60 TL series motor rebuild over the winter. Had it out on the lake this weekend to go through the break in procedure. After it was done I wanted to see what the WOT RPM's would be. The motor would not exceed 5200 RPM running about 30 MPH (non GPS). The boat is a 16 Tracker SC aluminum. The current prop is a 12 3/4 by 21. If the prop is correct for the boat and motor then does the motor need to be fine tuned?<br /><br />The VRO was removed and replaced with commercial pump. It now has the proper Champion spark plugs in it. Regular gas mixed 25 to 1 (for break in). New fuel lines, bulb and water seperator. <br /><br />Thanks
