wot rpm '82 mariner 90 HP inline 6
jamescody
I posted this over at scream and fly, but I just wanted to get the general consensus here<br /><br />I have an '82 Mariner 90 hp I6.....the owners manual states that the rpm operating range is 4500-5000 rpm. Talking to the local merc guy here he recomended running it in the mid 5's range ideally 5300-5400. I had to show him in his own shop manual what the recommended range for the 90 was, I guess he is used to the 115 - 155's.......anyways, would it hurt this engine to prop it above 5000...would I gain anything? I know the info on these 90's, supposedly equal holeshot as the 115's just not the same topend.....small ports, blah blah blah.......I run premium gas with 50:1 mix of Quicksilver P+, with max timing of 21 deg on the starter. I just dont want this thing to lean out if I push the rpms...The motor is on a fairly heavy 17 ft Aquastar, the prop is a 15 " pitch which is about 4900 WOT. I vented the prop to get a better holeshot, helped out a fair bit, but I wanted to try and run a nonvented 13" pitch prop and see how it was, but there in lies my dilemna, better and stronger holeshot, but the higher rpm...could always trim back I guess, but what fun is that?<br />Anyways<br /><br />Thanks for your help
rickdb1boat
Re: wot rpm '82 mariner 90 HP inline 6
Even with the 13" Prop, you should be OK. I assume that your figures are with only you on board. You will be about 100 or so RPM'S above 5000, but that should'nt hurt anything. Sounds like you are really proped correctly right now at 4900! But the 13" should improve your hole shot! Also, I would not run high octane fuel. It is generally recommended to run regular unleaded, as higher octane will makes your Motor run too cool!
