Re: WOT Question
You have to verify the tach. Simplest part of the equation. Sounds like it is right though. You are very close to the correct RPM. Gear Ratio is a possible cause and the shop that did the work should be able to help with that. The prop that was on there could have been tweaked slightly on purpose, so you are right to question what it once was. Does the guy at work know anything about it?<br /><br />Yes, Sea Ray may have noted 4600, but that could have been with no gear, one operator, little fuel etc. This could simply be about load, lots of stuff, full fuel, 12 passengers. When you check your WOT RPM are you trimming the drive out to get the most out of her? Smooth water? Bimini down? All of these things add load and decrease your WOT RPM. For example if it is near empty and all other factors are optimum, you may get the 4600, but with an extreme load, bimini up etc. etc. 4200. This would be an almost perfect (and unlikely) propeller compromise. If you find all else is correct and are still a couple of hundred RPM off, then you can have a prop shop take an inch out instead of going to the next propeller pitch. I am not saying that this is not an engine or mechanical issue. Just that there are multiple factors and any one can cause changes in the WOT RPM.<br /><br />Good luck!! We all go through this. I am trying different props now with mine too . . .
