WOT on startup
Texasmark
Amazing. How do you get enough CFM into the cylinders to do that.....not through a 5/16" vacuum hose.....650 CFM? No Sir.
Faztbullet
Take the throttle cable off and make sure throttle plates closed. Did you do any carb work as there are several types of base gaskets that will cause air leak under TP's
Tony1173
Yes I swapped out the old carburetor for a rebuilt one. And used the gasket it came with, which seemed to fit fine.
