WOT low rpm.
Meltedgears
I have a 1995 112hp spl evinrude and im having a problem with running at WOT it will only run at around 3000 rpms. I was thinking about checking the timing on the motor but Joe reeves method is blank. So I was wondering if timing could be my problem and what joes method was?
I have done a spark test and everyone would jump 7/16 and the compressions all read the same on all 4 cylinders. And it has 4 new champion spark plugs. The people I got the boat from said it just had its spring tune up so I didn't know if he messed with timing or not.
Honorary Supreme Mariner
What prop on this motor ?--------What boat ?-----Has boat been checked for extra weight ( water logged ) perhaps.-----Are orange / blue stripe wires going to the top coils ?----Timing does not go out of adjustment on these motors.----Who checked compression and what are the numbers ?
Meltedgears
Boat is a Crest Savannah pontoon, prop is 13 3/4 x 15, and orange / purple on first cylinder orange /blue on other top cylinder
Meltedgears
Orange / pink and green on bottom cylinders, I checked compression and they were 115.
jakedaawg
A lot of folks never bother to properly prop pontoons. That crest is like a submerged log. Big and heavy, as pontoons go. All else aside, does motor run well? Has it ever done more than 3k rpm? Have you witnessed this?
Meltedgears
That I don't know they said it would go 25mph with 11 people on it. Doesn't seem to be planing out like it should. I have had to put a new fuel pump on it because they switched it to a holley fuel pump and it flooded it out after driving a little bit. So I swapped it back to a vro pump seems run ok to me but thought it would run a little higher on rpm.
Meltedgears
I've got a mph app on my phone going to see what it runs with 3 people on it.
