Re: WOT 3500 rpm HELP PLEASE
Don't do that, your numbers are way off, so the info is wrong. Think about it, if you take a 15" pitch and calc. it out, at 3500 rpm, with even a 1.8:1 gear ration, you would only get about 27 mph with no prop slip, so, your boat has either broken a few of the known laws of physics, or more likely, your tach has several pole settings, and yours is set on the wrong one. More than likely you are really getting aprox. 4800 if you have a gear ratio of 2:1, OR 4300 if 1.8:1. I have no idea of what your ratio is, but that should be easy enough to find out. A 12" pitch would be way too low, and you would be at or past red line if your tach is on the wrong setting with such a prop. Good luck.
