Re: ??? worth rebuilding ???
Before you decide to rebuild the motor try a decarb, 100 pounds is not a very low reading, you may just have a slightly sticky ring,(I have just had my 1971 125hp throw a ring and the compresion test was only 40 pounds). As for rebuilding the motor I have to say that I found plenty of dealers on the net who have the parts available in the US, a bit more of a problem here in the UK but if you are willing to do the leg work and can do the rebuild yourself you should be OK.<br /><br />Best of luck<br />Richard
