I have a 14' aluminum boat and the wood on the transom needs replacing. There is a strip inside the boat that runs the width of the transom at the top and is about 6" high. There is also a piece on the outside where the motor mount rests about 14" wide and 16" high. Is there anything I should know about replacing the wood? Is there another material I could use that is cost effective? Thanks
