Re: woo hoo we are finally here
thomvw, gald to hear from you. i new you had one too.<br /><br />on the back of my transom where the sea drive enterd through the hull, it started leaking. ive since tore out the wet and rotted wood, it was rotted about 8-10 inches in each direction. i dug out the wet wood untill i hit strong, dry wood, made a new peice outa 1/2" ply of that same size and glassed the **** outa it. then i did that 2 more times. now its rock solid, probably even more so than stock.<br /><br />the entire rest of the transom was fine as were the "knees" and stringers.<br /><br />i havent yet to put my sea drive omc v6 back on, so i got a 30 inch setback bracket and im gonna convert the sea drive to a standard tilt trim version.<br /><br />the rest of this boat is very heavy and rock solid.<br /><br />i hope this helps anybody else, and i look forward to hearing from more sportcraft owners.<br /><br />mike
