DallasJeff
- Apr 30, 2008
- 64
Recently acquired a '54 Johnson 10HP outboard from Craigslist.
Got on the water last night and the motor started up on the second pull. It ran fine for about 2 minutes but when I turned the throttle from "start" to "shift" It died. Started back up and ran about 2 minutes with throttle in "start" position. Then it died and would not restart.
Vented the tank and fished for about an hour and tried the Johnson again and it started on the second pull. Ran for about a minute or two then died and would not restart. After thirty minutes tried it again and it started on first pull. Again ran for one minute and died. Would not restart.
Reading around this forum looks like the next thing to do is get a pressure gauge and check cylinder compression and spark (should be > 100 psi, right?). I'm also considering cleaning and rebuilding the carb including new float and needle. The coils are supposedly good, replaced by the previous owner. This is the first outboard I've ever owned or operated so working on it is new territory. I also acquired a repair manual published by Clymer.
Any suggestions or help with diagnostics is appreciated. I'll keep a running log of my diagnostic testing and repairs in this thread.
