It is pretty easy to see if the choke is working, pull off the hood and look at the front of the carb when you pull or slide the choke knob, it should cover the throat of the carb to restrict air and rich'n the mixture of fuel to air as well as help with vacuum to fill the bowl to help start the engine, after you get it to fire or running you turn the choke off. If you have a pull start motor, it should be a manual choke.
