'88 4.3l OMC Cobra
I'm feeling a bit dumb. Had my boat out the other day, started and ran to 1800 RPM and then would backfire. I figured timing and didn't run the boat much when I noticed I was still getting water in my gear oil. Not a ton of water so I drained the gear oil, replaced it and will get to that later.
Problem was I was looking at my plug wires and they were not in the correct order so I put them into the correct order. Would the boat have run if they were incorrect? Maybe they were right and It was me that screwed up.
So I got the engine in compression cycle, cranked the engine with a 5/8 wrench to 0 TDC and started wire #1 with the rotor pointed at it and then went around with the rest. I'm positive I did this correctly with firing order 1,6,5,4,3,2 clockwise.
Went to start it and it just cranks. Plugs are black now but and they were new. Wires, cap and rotor are new. Havent done points but was getting ready to when I screwed things up. Right now I'm charging the battery as its almost dead from the cranking. On a side not, the negative terminal on the battery got very hot.
I probably should be doing some more troubleshooting before posting on here but my heads spinning and I need to wait for the battery to charge. Any ideas are appreciated. Thanks.
