Wont shift into fwd when it does it slams hard?
ilove2fixx
Hey guys , ok long story short.. i told my uncle not to touch the boat because he dont know how to operate it.. well i came back and it wont shift onti first , after many attempts it will catch... but sometimes it revs high and catches and that impact is nasty.. i hope he didnt mess anything up..
What he did was drive it with tilt like 75% down and he said he only drove it for a couple min slowly and docked it on the sand bank..
Also i did go over some rocks earlier, maybe the prop was hit ? IDK this damn boat is a nightmare lol
ilove2fixx
Pull it out and double check the shift cable adjustments
I hope i didnt kill the drive.. i took a look today and there s little chunk missing on the corner of the lower unit by tye drain plug.. about 1/3rd of inch deep and about 2 inches around.. : (
Im praying its not from that
Here is a pic.
Bt Doctur
Need a better pic without the finger, in that area is the shift spool and selector. A dented case will affect the shifting
ilove2fixx
I took out The drive today and it looks fine.. prop locks when i put the that sift rod in the center..
The problem is the end of the shift cable with the metal bracket..it does not move back or forth its stuck , maybe thats the problem the shift cable got damaged from the hit ?
thumpar
It looks like the drive has taken a beating before with the skeg guard on it.
ilove2fixx
Maybe its from that one time ? But did u see the last video ? Its stuck , is that normal or possible from a hit like that ? That itll throw off the cable or cause it to get stuck like this ?
thumpar
Have someone move the shifter and watch what it does. That should not move freely.
Bt Doctur
If its not disconnected from the shift plate it wont move.
If it is disconnected from the shift it was overheated and fused the shift cable where it passes by the Y pipe
ilove2fixx
It moves back and forth when changing gears at tye helm , so whats next.. im praying its not the drive guys.. man that would suck
ilove2fixx
Ok i put the drive back and it locks ccw in fwrd but doesnt lock in rev CW ? It barely grips and slips ?
ilove2fixx
lol it seems im asking questions and solving my own issues my self..
Ok i took everything apart and put back correctly.. and readjusted cables .. now i can shift again !
But sometimes engine still stalls.. it seems like im getting a big surge of air around the carb like a vacume leak and then it stalls.. ?
thumpar
It probably needs a new lower shift cable. The shift interrupt is most likely the cause of the stall. The inner sheath gets warn and the cable doesn't have the travel it should.
ilove2fixx
I looked at the interuoter upon shifting it doesnt even move yet the engine stalls sometimes ? I do hear like a vacuum leak or high pictched air around the carb is that normal ? This is my first carbed engine lol
Nope, it's not,.... What carb ya got,..??
