Ok, after fixing my idling problem, using idle mix screws to keep boat running now I put it in the water and now I have a new problem. The boat idles great, runs great gets up on plane great, but now the max rpm at WOT is right at 4000 rpms. Before changing the plugs, plug wires, fuel filters, and adjusting the carb, the boat pulled 4400 rpms and 44 mph. Now it does 39 at 4000 rpms.
Any ideas on where to start to determine what caused this after doing maintenance on the boat??
Motor is 93 OMC 4.3liter with Holley 2300 2 barrel carb, OMC Cobra outdrive
Thanks in advance for any insight.
