1979 evinrude 35hp 35952A
engine wont idle, will start, keep alive by working choke on and off, rebult carb, new fuel pump, compression 123psi both, spark looks good on both, but bottom plug is wet, with gas. looking at cam follower, it is almost at begining of cam, to the left of it, I see what looks like 2 inverted "V" 's on the cam,is that the mark? the manual calls for C location and note 4, but it doesnt look like the photo at all, no adjustment on the throttle rod, could the syn n link cause the no idle, and gas on the bottom plug? correct adjustment? in the pic the screwdriver blade is where I see the mark.
