timing is good, spark is good ,carbs look clean and compression is good were do i go from.
M mocha0403 Cadet Joined Apr 13, 2008 Messages 12 Apr 25, 2008 #1 timing is good, spark is good ,carbs look clean and compression is good were do i go from.
T thellcon Cadet Joined May 7, 2007 Messages 28 Apr 25, 2008 #2 Re: wont idle in the water Carbs look clean or ARE clean? If the low speed jets are not perfectly clean they are not clean at all!
S Solittle Fleet Admiral Joined Apr 28, 2002 Messages 7,518 Apr 25, 2008 #3 Re: wont idle in the water My daughter's car looks spotless on the outside but on the inside - - - - you get my drift?
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Apr 25, 2008 #4 Re: wont idle in the water idle must be set in the water and in gear. http://forums.iboats.com/showthread.php?t=244013
