fenderfuel
- Sep 14, 2015
- 5
So I bought this boat a year ago and I only just got it on the water this year after refurbing it. The motor would only run up to 1/4 throttle then after that it would rev up momentarily, then bog down and surge. I figured it was a simple carb issue, so I cleaned that twice with compressed air, carb cleaner, and an ultrasonic cleaner. Its really clean. Motor starts right up, idles low and doesn't surge or have a rough idle. Anyways, I noticed the fuel line from the gas tank to the motor was leaking slightly when under full pressure of priming, so I replaced that and added an inline fuel filter just after the primer ball before it goes into the cowl.
Now, the motor will start up and run for about 10-15s in neutral, then bog out. Compression test was 125psi in each cylinder, there was spark on both cylinders, so I am guessing its a fuel issue. Does anyone else concur? any other ideas?
