wont go in gear
catfishchris
This is kinda hard to explain but I've always recieved really helpful hints before so I'm gonna give it my best in explaining. Hopefully someone can help. I have a 77 55hp Evinrude motoe and Kingfisher boat. We were at the lake and ran thru some shallow water and hit a log or something. Didn'y know it was only 3ft deep. Anyway after that I had trouble getting it to go in gear. It would throttle up before the gears would catch so I figured I had sheard a pin. Come to find out my motor doesn't have a shear pin. When I disconnected my cable from the motor I could put the prop in gear by hand..so there's no problem in the lower unit. When I move the shifter it throttles up and the gear cable moves in and out...but when I hook it all back together-NOTHING. Just the throttle works. I adjusted the cable from the beginning of the threads to the end and then back to the original position. Still no luck. Can anyone help??? Please the cats are biting and crappie will be soon..I NEED MY BOAT!!! :mad:
JB
Re: wont go in gear
Moved to Outboard Questions.
