Re: wont go forward
Well that is a head scratcher for sure. You say it shifts into forward gear, just can't apply power. That would indicate the shift linkage is ok, or at least operational if not totally ok. You also indicate it will drive in reverse and by assumption the water pump works. That rules out a broken drive shaft.
So, I have to ask, when in forward and in no-drive mode, is it making a bunch of chattering or grinding noises? That indeed would indicate a very worn out clutch dog and forward gear.
However if it is just a smooth slippage with out grinding, it certainly points to a spun prop hub. What I can't understand is why it doesn't slip in reverse. Well, whether or not that is the case, it is the first thing you should check. Make a mark on the prop nut, and a second mark on the propeller, aligned with the first mark. Then run the motor till the suspected slippage occurs. Stop the motor and check the marks. If no longer aligned, the hub slipped and you just need a new prop. But if still aligned, repeat the test--there is a slim chance it stopped slipping in the same position.
