70hp chysler cranks over ok but only backfires?Motor is on a stand in garage
E edgar Recruit Thread starter Joined Jun 28, 2006 Messages 3 Jun 28, 2006 #1 70hp chysler cranks over ok but only backfires?Motor is on a stand in garage
Z zoltang Cadet Joined Apr 29, 2006 Messages 16 Jun 28, 2006 #2 Re: Won,t Start did u check if theres gas going in? Motor should be conneted to a water source.
E edgar Recruit Thread starter Joined Jun 28, 2006 Messages 3 Jun 28, 2006 #3 Re: Won,t Start zoltang said: did u check if theres gas going in? Motor should be conneted to a water source. Click to expand...
E edgar Recruit Thread starter Joined Jun 28, 2006 Messages 3 Jun 28, 2006 #4 Re: Won,t Start I use the muffs when I crank it.Ialso tried spraying gas directly into each carb.
Z zoltang Cadet Joined Apr 29, 2006 Messages 16 Jun 28, 2006 #5 Re: Won,t Start well, spraying gas into the carb only keeps the engine going for a short period of time, have u tryed cleaning out the carbs? the flowter might not be working properly
eurolarva Rear Admiral Joined Jun 24, 2003 Messages 4,182 Jun 29, 2006 #6 Re: Won,t Start A back fire is usually a timing issue not a fuel issue. Are you sure the plug wires did not get reversed?
