wiring
elwilliams13
got a 91 evinrude 225 put in a new oil tank for the vro. old one not connected, where are the wires for the horn come out of? what color and connection type are they? should I change the pulse limiter to the blue even if mine seems to work? the manual shows an inline limiter but mine screws into the crankcase is this normal?
Bluefish
Re: wiring
My book says V4 uses screw in V6 has the in line. My book says gray terminal strip NOTE my book is for 1990 up to a 175hp engine. What I did want to *STRESS* is use a pre mix until you verify oil consumption if VRO was disconnect my have been a problem.
