wiring problem
jSioKos7964
hey all! i have a 97 scout 192 sportfish i have acquired and the electrical panel is a mess.nav lights don't work,bilge pumps,etc, does anyone have a wiring schematic for the panel?
Beefer
Re: wiring problem
Can't help with a diagram, but if it were me, I'd probably pull everything and start with a clean slate. You'll also know everything going on with the electrical when you're done.
blueoval1
Re: wiring problem
Check the sticky at the top of the page in this forum. It will at least give you a starting point to work with.:)
Welcome to Iboats!:D
tashasdaddy
Re: wiring problem
yep, sticky's has good info. and i usually start from scratch.
