Hi all,
Long-time lurker, but I recently bought a 2007 180cc Sea Boss, so I've been a little more active as I've taken on projects. My current one is putting in a marine stereo and speakers. I've done the project once before in a smaller Skiff, which was not too difficult. However, the one issue I'm finding with my Sea Boss is that there isn't (to my knowledge) a bus board under the center console that has open terminals for me to connect my wires to. Instead, all of the wires seem to come/go from the switchboard into a large pipe into the floor which goes back to the battery and I presume a bus board as well, since there are only the single positive/negative wires coming off the battery.
My question is, what would you recommend for this situation? My stereo requires both an Ignition 12+ and a Battery 12+. I've got it temporarily working by simply combining the two wires and putting them directly to the batter when the boat is running (and taking off when the boat is off to avoid battery drain).
On my switchboard, there is a top row of switches that are all being used by the various electronics/bilges/pumps in the boat. There is a second and third row that have little "nubs" for switches on the outside - as in, there is no switch or toggle to be made. Under those switches on the inside of the center console, the wiring seems to be done in series so as to keep up the circuit. A picture is attached of the bottom right switchboard. Can I somehow hook up the wire to one of these empty switches while keeping the circuit fine?
Thanks again in advance for your knowledge and help.
