Re: WIRING HARNESS
Timmy, My SeaRay had a wiring diagram in the owners manual. It included dash, instruments, ignition key etc. Since the motor was a Mercruiser, with a plug and a standard wiring harness, it was likely integrated to the Mercruiser. You can look for an aftermarket generic harness. Maybe you can find one that is intended for your engine. It should be able to be enhanced to include unique stuff you need.<br /><br />If it were me, I would look around for an aftermarket harness, and when that failed, I would buy bulk multi-conductor wiring (ie. Trailer wiring is 4 conductor) to service power, ground, ignition, start solenoid, fuel sender, trim sender, tach sender, temp sender, warning buzzer, trim/tilt, oil pressure sender etc., and make my own new harness.
