I'm replacing the switch to a 3 way Johnson bilge pump switch and also replacing the pump with an automatic Johnson L650UC. I'm going to have to run all new wires as the current pump and wires leading to it has no power and the wires are all bundled with the rest of the wires in the boat and I'd never be able to figure out where they all go.
1. Will the new pump/switch come with sufficient wire to run from the dash to the engine compartment?
2. If not, what kind of wire should I get for the task
3. I'm attaching it at the lowest point of the bilge with a vertical bracket. What adhesive is best? I've got 5200 but have heard a lot of "no's" to it
Everything should be in by the weekend so just trying to see what I need to have on hand to make the project a success. Thanks
