Wiring for ignition module
dmiles452
My 5.7 Mercruser quit while pulling into the dock. (Lucky Me) In diagnosing the problem the engine will not refine. Putting gas down carburetor has no effect. So I removed the distributor cap and saw that the Module had disintegrated. I purchased a new one only to find out that the old module had two screw type connections. One pole had two white/red wires connected the other had one white/green wire connected for a total of three wires. The new module has one white/green wire and one white/red wire and a black ground wire. Where do I connect the two white/red wires that were on the same pole? I am assuming the white/green from the new module connected to the white/green of the engine harness.
