Re: wiring for dummies
Does the motor have a 12/24 switch on it or is it a 24V only motor? It makes a difference. We need to know how many wires come from the motor to the plug. If its a 24V only motor there will be only two wires in the motor harness. If its a 12V and 24V there will likely be three wires in that harness (Red, Orange, and Black or White).
24V ONLY: BAT 1 POS to BAT 2 NEG. BAT 2 POS to Red wire in plug. BLACK (or white) wire in plug goes to BAT 1 NEG. In this configuration the batteries are in series and only two pins on the connector are used.
12 AND 24V: Same as above, but connect the ORANGE wire from the plug to BAT 1 POS. In this configuration the red wire feeds 24V to the motor. If you switch to 12V the orange wire feeds 12V.
