WIRING DIAGRAM
JACKULLRICH
I HAVE A 1988 JOHNSON 110HP MODEL J110TLCC. I AM TRYING TO PUT GAUGES IN MY BOAT AND I CANNOT FIND ANY WIRING DIAGRAMS, ON HOW TO HOOK THEM UP. DO ANY OF YOU KNOW. THANK YOU. :)
rickdb1boat
Re: WIRING DIAGRAM
Actually, if you go to the link below, it should have everything you need!<br /><br /> Teleflex
JACKULLRICH
Re: WIRING DIAGRAM
RICK THANK YOU I AM PUTTING IN THE 7000 RPM TACK,TILT AND TRIM,VOLT METER, AND ENGINE TEMP GAUGE.
JACKULLRICH
Re: WIRING DIAGRAM
I FORGOT TO MENTION ONE THING, THESE GAUGES ARE FROM OMC CORP, IF THIS WILL MAKE ANY DIFFERENCE. THANK YOU AGAIN. JACK
JB
Re: WIRING DIAGRAM
Hi, Jack. (No pun intended)<br /><br />Please don't use all capitals. It is viewed on the net as shouting.<br /><br />Good luck. :)
rickdb1boat
Re: WIRING DIAGRAM
Will not make any difference what brand. They all hook up the same. Just follow the diagrams at the Teleflex site and you will be fine.
JACKULLRICH
Re: WIRING DIAGRAM
Thank you Rick I am going to give teleflex a try. Thank you again for your quick response. Jack :D
