Re: wiring diagram to hook up MK 1 DC on board charger
The MinnKota MK DC1 is an "alternator charger". It charges the (trolling motor) battery off the main engine while the main engine is running, then cuts the connection when the engine is off, it operates like a battery isolator or ACR.
How long you run your outboard, and how much charging current the outboard can provide is the limiting factor on how well the MK DC1 will work for you. Run on plane for a few hours a day and it would probably charge OK. Run 15 minutes to your fishing hole, fishing for 8 hours, then run 15 minutes back to the dock,,, wouldn't charge the TM battery much...
I haven't seen one and don't really know how to wire it up, but MinnKota should have something on their website, or the instructions that came with the unit should tell you how to connect it. You will have to run wires from the engine to trolling motor battery and either put the MK DC1 back by the engine or by the trolling motor battery. Lots of places it could be mounted and ways it could be connected because of it's mounting location, so you will need to be more specific as to where you are going to mount the DC1 for wiring suggestions. But yes, it needs to be wired to the outboard/main battery, and the trolling motor battery,,,, and I think the ignition switch, but I'm probably wrong as I have never used 1 of those. Check MinnKota's website.
