Wiring connector
rdtenn
Can anyone tell me where I can purchase the wiring connector that plugs into the electric fuel pump on my 1997 Sea Ray, 190, 4.3 engine. I have had to install a momentary on switch to turn on electric fuel pump to put fuel into the carb. since carb. runs dry after sitting for a week or so. Had carburetor overhauled and plugs sealed but still the gas disppears and will not start cold unless I prime with fuel or whatever. After initial cranking runs fine until it sits for a few days, then a repeat of the same. Now sometimes with the switch fuel pump does not run unless I wiggle the connection at the pump then it runs...I hope it is the connector and not the fuel pump, want to try connector first.
Also, is a regular car or truck fuel pump for a 4.3 the same on a boat. If so I would assume electric fuel pump would be cheaper to buy from NAPA or a new car truck dealer rather than a boat dealer. Does anyone know this answer? Also if anyone can give me advise on the fuel pump connector or a possible fix I would appreciate it very much.
