Wiring 650
billybandman
Same motor as mentioned in above post. '69 650.<br /><br />On the wiring harness,plug side, above the wiring harness there is an electrical device, that looks like a heat sink, two wires, one from each end, are routed up into the top part of the motor, under the flywheel. The third wire, in the center of this device is not connected to anything. In the wiring harness there is a red wire that is not connected. This red wire tests to have 12v current. Should these two be connected?
JB
Re: Wiring 650
Add info to your original post, hi c. Don't start a new topic.
