I have the appropriate Seloc manual, but it does not cover a couple of items and only has a schematic for my motor with a generator (mine does not have a generator).<br /><br />Wiring harness from motor has four wires other than unused ones and starter motor leads:<br /><br />1- temp light circuit (brown)<br />2- solenoid circuit (white)<br />3- magneto circuit 1 to key switch (black)<br />4- magneto circuit 2 via runaway switch to key switch (black)<br /><br />From what I can tell, the key switch simply shorts the two magneto circuits together. Is that all it should do?<br /><br />Engine off, battery disconnected at the battery, motor wiring harness disconnected from the boat. When I connect my Ohm meter to the magneto circuit 1 to key switch (black) wire and to ground I get continuity (0 Ohns). Is this correct? Same for magneto circuit 2. Is this correct?<br /><br />Is the design such that because the cylinders fire at different times, one or the other black wires is always grounded so the key switch passes the ground to the other circuit to ensure the motor wont fire when the switch is in the off position?<br /><br />Why do I ask?<br /><br />The harness was 46 years old and pretty bad shape, so I made a new one. I just want to make sure it is rewired right before I try to fire up the motor. <br /><br />Thank you.
