Ok, I dropped the lower unit to change seals. As I was in there I discovered that the electrical wire for shifting(1963 electromatic Johnson 75hp) was starting to fray. I put it back together and sure enough it will now not go into gear. Dropped it again turned the key to the on position and could hear and see it spark out the side of the wire. My question is can I use any 12 or 14 ga wire and silicone it the hole where the wire goes so not to get water in or do I need the factory wire which has the rubber coating and the larger trubber ribs on it to seal the hole?
