Just a general Q re: winterizing ( I know it is a bit early but winter comes quick here in New Brunswick )
I am not a mechanic but am somewhat "handy" and the dealer is quite a distance away......given that....... is it very hard to perform all the winterizing steps required for this motor...seems pretty straight forward except for a few things.....
wash
drain fuel
clean carb<----will need advice on this one
remove spark plug
change oil
change gear case
grease
coat electric start pinion gears with grease <-----will need advice on this
comments........is it possible to obtain an exploded view of this motor???
thanks a lot !!!!!
wash
drain fuel
remove spark plug
change oil
change gear case
grease
thanks a lot !!!!!
