Re: Winterizing Question - Fogging Process
Thanks for your help. After putting the gas/stailizer/2 stoke oil mix in the fuel filter, how long should I run it to effectively coat the inside of the engine? After doing that, how necessary is it to pull the plugs and do step #2? It seems like you would do one or the other?
Even though you put that concoction into the fuel filter, the volume of fuel flowing in will just dilute it thus it doesn't coat the engine as you might think. It does however definitely do good things to the fuel injectors - That is the main purpose with coating piston/rings etc. second.
Do you have to do both, maybe not - but I am the anal type that likes to ensure the cylinders, pistons and rings get a good 100% shot of fogging without any combustion or fuel burning or rinsing it off etc.. I still like squirting it down the TB as well to get a good mist on the manifold and intake valves as well (bad for the MAP if applicable - I am not sure?????).
To top it all off I had added fuel stabilizer to the tank a month ago during my last fill - this way after several weekends of boating I know the mix has made the rounds...
This has been my process the last few years/seasons.
Overkill? Probably. But I will sleep better the next 6 months....
