Winterizing Polaris 750 SLT
asherngeese
I need information on how to winterize my Polaris 750 SLT. I have been told to locate the water intake line?? and then flush a 50/50 solution of antifreeze through it into the engine. Can someone assist me with the proper procedure?<br />Thanks.<br />-Steve
asherngeese
Re: Winterizing Polaris 750 SLT
We have had great weather here until the last 3 weeks and I have kept it stored in a heated garage but wanted to move it to my shop which is not heated. It has been started on a regular basis to keep everything lubed - but yeah - last minute stuff. Got the battery on a trickle battery tender. Wanted to flush it out and fog it before disconnecting the battery since I would probably need to start it or at least turn it over. Won't put it back in the water until late April or early May. Is the flush kit opening the brass capped plug in the water manifold and does it require a special fitting? If so, where can I locate a flush kit or is there another connector that can be used. I don't have a book with the PWC and our local dealer went out of business. Usually I let them winterize it but no one available this year. Thanks for all the help.
Jeff Walkowiak
the cap is just a common garden hose fitting un screw the plastic cap pour some anti freze in start it up and blow out the excess water in the exhaust.
Jeff Walkowiak
If you scroll down the pwc topic page you will find a lot of posts to give you an idea on all the tricks of winterizing a jet ski
