Re: Winterizing A Motor (a different question...)
Any winterizing topic grabs the attention of a Canadian....lol<br /><br />I winterized mine today actually.<br /><br />Stabilize the fuel<br />Run the motor (if you can) for 10 minutes or more<br />Pull spark plugs<br />Spray fogging oil into cylinders<br />Open throttle plate wide open by hand<br />Spray fogging oil into carb throat<br />Rotate flywheel by hand a few times, or with key (kill switch enabled)<br />Replace spark plugs<br />Drain lower unit, checking for debris & water<br />Refill lower unit with fresh oil & new plug gaskets<br />Vaccum & clean entire boat<br />Remove portable gas tanks for storage<br />Remove batteries & electronics for storage<br />Position motor fully downwards to ensure water drains out of prop hub<br />Cover boat or store inside<br />Go online to read boating forums until it warms up again in the spring<br /><br />Hope that helps.
